Carbon anti-slip pa...
Carbon anti-slip paste or.. Loctite?
9 Users
10 Reactions
I have had my road handlebars slip a bit, I think my stem isn't a particularly good design, so I was thinking of changing it. But then I realised maybe I could simply use something to help prevent the bars turning.  I know there's carbon anti-slip paste for this, but I was thinking threadlock could help slightly bond the bar to the stem which, combined with the pressure of the stem plate would do the trick.
I have only seen two kinds of anti-slip compound - one was a light oil with grit in it, which I'm told is bad, the other was tacky cream like a glue stick. I didn't think either were particularly useful at the time.
Posted : 29/01/2024 1:46 pm
I have/use the gritty stuff, no issues to report and it does what it's supposed to. I only really use it on stem face plates and seat posts.
Posted : 29/01/2024 1:58 pm
I used some of the carbon gripper paste from Halfords this week and it stopped my bars spinning so easily. Only cost 3 quid so I didn't expect much but it seems to have worked.
Posted : 29/01/2024 2:03 pm
This doesn't feel as obviously gritty as some and works well IME
Posted : 29/01/2024 2:25 pm
fruitbat and fruitbat reacted
 csb
Will the carbon stuff work on a slippy aluminium seatpost?
Posted : 29/01/2024 5:09 pm
dc1988 and dc1988 reacted
Sure will, it’s recommended to use with droppers (so you don’t have to clamp the tightly)
Posted : 29/01/2024 5:28 pm
dc1988, csb, csb and 1 people reacted
I have some gritty stuff still.  It's a bit.. runny,  not exactly grease, but I guess that's the point.  But I also have Loctite.
I thought I'd read that you weren't meant to use  the gritty stuff?
Posted : 29/01/2024 6:15 pm
I have Finish Line Fiber Grip, it's more of a grease consistency but isn't sticky, definitely not runny.
Posted : 29/01/2024 6:22 pm
Just do the bolts up slightly tighter.
Posted : 29/01/2024 6:24 pm
NO DONT DO THAT!!!!  Especially if they're carbon bars.
Use a troque wrench to torque them correctly.  If they're carbon then I'd always use carbon assembly paste AND a torque wrench.  all too easy to crush carbon bars if you just keep tightening.
Posted : 29/01/2024 7:04 pm
I thought I’d read that you weren’t meant to use the gritty stuff?
Trek 2011, context is the steerer: https://thegoldenwrench.blogspot.com/2011/09/tech-bulletin-from-trek-regarding.html
Posted : 29/01/2024 8:13 pm
mashr and mashr reacted
the muc off carbon fibre paste is brill. and smells fabulous
Posted : 29/01/2024 9:01 pm
