Can anyone with a Spectral CF confirm if it is possible to run a continuous outer gear cable through the frame?
If it helps I have a Spectral AL 29er, and I can't run a continuous outer without drilling/widening the cable routing holes, which are thinner than the outers to stop the ferrules falling through. I'm guessing the CF has similar interior routing if it also comes without continuous outer cable as stock.
Ok thanks - I had a Canyon Nerve with the same setup.... I was too chicken to drill the frame!
On the Carbon one, the photos appear to show plastic inserts into the frame, which *might* be adaptable....
Reason for my question was I was thinking about getting one and I just want to make sure I can weather proof it for UK winter riding!
