Can you retrofit ba...
[Closed] Can you retrofit banjo bolts to current gen Shimano Deore Levers?
4 Users
I want to do something horrendous with the brakes on my 29er, ideally running them in a position as close to that of a road STI - edit: more like a TT brake lever actually - as possible (on a touring 'butterfly bar' to make things worse! 😉 ).
Having the hose come straight out the lever doesn't work as it would need to perform a lengthy 180 degree arc to get back to the headtube, but a banjo fitting would be ideal.
I'm just not savvy enough with current gen disc brakes to know what's possible...
Ta
Posted : 03/01/2021 8:43 pm
 kevs
I would’ve thought so, ive just fitted some banjos to some mega old gator brakes using an Uber bike universal hose kit, cam with all the fittings needed.
Posted : 03/01/2021 9:04 pm
The end of the threaded part of the lever outlet isn’t engineered to seal on a banjo fitting.
Posted : 03/01/2021 9:51 pm
Thanks gents, looking at the exploded diagrams I think I can see what hamish means, you'd be tightening an o-ring onto the end of a thread which doesn't sound healthy.
Plus the actual parts are like hen's teeth anyway, 'banjo units' seem to retail for £30 ish if you can even find them so you'd need a hose assembly already complete with the right parts at either end.
File under 'too much hassle even if it was possible' 😀
Posted : 04/01/2021 10:40 am
Could you use the GRX sub levers in addition to your regular levers? They have an appropriate hose exit, but require a standard lever also for the reservoir.
Posted : 04/01/2021 1:05 pm
