To cut a long story short, I had to cut a carbon seat post out of my ibis mojo because it got stuck.
I've got a reverb to replace it and now it Wont go in! I've tried a Thomson as well which also didn't fit.
They seem to go in about 7cm which is the length of the alloy insert in the seat tube and then wont go past that.
Any ideas?
Did you cut all the old post out?
Have you shined a torch down the tube to see what is causing the obstruction? I presume the old post went in fine beyond 7cm?
Edit: 'shined', get me and my crumby grasp of the lingo.
Yep cut it out.
I could be wrong but I am pretty sure there is no alloy insert. Well there wasn't in my Mojo or my current HD anyway.
Can you clarify?
Yep shone torch down and there's nothing there. After the insert the tube widens to To the seat tube size. The seat tube doesnt even touch the frame because of the insert.
There no noise when I the post stops so I'm certain it's not hitting anything.
What size is the reverb (diameter)?
It's a standard mojo, not sl or hd and has an alloy insert.
It's gone off the ibis site now but this link refers to the carbon insert of the sl so I'm alnostcertain it's alloy in mine
http://www.ibiscycles.com/bikes/mojo_sl/#details
It's a 31.6. Def right size
It's not the rivet holding the front cable guide causing it is it? I have seen that once on a seat tube.
Just been and checked and nope it's not that.
It just seems to go so far and then get stuck, like the posts get wider as they get nearer the seat clamp end.
Can you borrow a different 31.6mm seatpost?
Ivetried two already, the reverb and a Thompson which both fit fine in another frame.
It was a 31.6 ritchey that was cut out that was stuck for a year or so.
I can only think it's something that's happened when cutting out the old one.
Try greasing the post, and twisting it as you push it in - if it's tight.
Greased, pushed, sworn already! Off to the lbs tomorrow for some reaming time.....
Good idea, the last thing you want to happen is to damage the post or frame out of frustration!
Got it faced today and its fine. Build up of grime appears to have been the problem.
