Cant get rouvy to "...
Cant get rouvy to "see" my trainer - help please
5 Users
Have just switched from Zwift to Rouvy for a change.  Can get it all to work easily enough on my android, but when I login into laptop I cannot get the app to pick up the smart trainer.  I have windows 11 laptop with necessary specs.  Have turned off blue tooth on phone to avoid pairing with that - but I cannot get laptop to pick up the trainer at all.  Would like to run from laptop to connect to bigger screen.  Any advice.   Zwift ran just fine fyi.
Posted : 16/03/2025 6:53 pm
Have  you tried using a USB ANT stick and have you recently updated the firmware on your trainer?
Posted : 16/03/2025 7:53 pm
 si77
I had to buy an ANT+ USB stick in order to use my laptop with Rouvy. (Had previously used an iPhone and that had ANT+ connectivity, but my old Windows 10 laptop doesn't have it built in).
Posted : 16/03/2025 8:15 pm
I run Rouvy on a Windows 10 surface pro and connect to my Wattbike Atom via Bluetooth. No ANT+ required. What trainer do you have ?
Posted : 16/03/2025 8:42 pm
As above, when got new laptop with W11 had same issue. Got Ant+ dongle and updated drivers.
Was another thread on it not so long ago.
Posted : 16/03/2025 9:05 pm
I have W11 with wahoo kickr core trainer - the rouvy app does not pick up the HR either
Posted : 17/03/2025 1:03 pm
my android phone works with the app and connects to everything instantly, which I reverted to yesterday after spending over 2 hrs trying to get laptop to work!
Posted : 17/03/2025 1:06 pm
