I need a SRAM hose to fit a code rsc (00.5016.168.170) but no where has stock! Can anyone help?
I've found a similar part (00.5016.168.150) on amazon, would this work? https://amzn.eu/d/dUWc4Vb
Have you tried asking a local bike shop to source one through their supplier chain?
Have you checked the European sites? The SRAM hoses aren't cheap and I think only come in pairs...
https://www.ebay.co.uk/itm/274367223847
https://www.bike24.com/p2231983.html
I really need it before this weekend. @DickBarton - those links aren't in stock or long delivery times.
I think (don't sue me) that all brake hoses are the same diameter, so I think (again don't sue me) you could use anyone's DOT hose. You'd need to buy the right connectors (obvs) but you get those with the bleed kit you're going to need anyway.
As per nickc.
Bike arrived with shimano stuff and as it was internally routed, I just swapped the master cylinders / calipers using the shimano hose but new sram hose barbs and olives
Everything is working and I've not been killed to death in over a year.
If it is just connectors I think Wiggle sell a Lifeline connection kit that will fit SRAM brakes...
Depends on length ?
Might be easier to buy a complete brake
Code hoses are specific and expensive, so buying a spare lever and caliper is a bargain, surely ?
