Cannondale / tapere...
[Closed] Cannondale / tapered fork headset reducer question
7 Users
Hi
This has probably been asked on the forum before. I have a cannondale prophet frame that I need to fit a tapered set of fox 34 forks to. Just wondering what headset is needed and if anyone has had any experience of fitting one before?
Cheers.
Posted : 01/11/2015 7:18 pm
Posted : 01/11/2015 7:24 pm
Hope Pick 'n Mix will work.
1 x Hope Pick 'N' Mix Headset Cups (4) Top - 1.5" - 1 1/8" Step Down Traditional (49.57 dia)
1 x Hope Pick 'N' Mix Headset Cups (F) Bottom - 1.5" Traditional (49.57 dia)
Is what you need.
That Hope type 4 didn't fit my jekyll frame (1.5 fitting a tapered fork), but I can't remember the reason why. The KP205 one Rorschach linked to did - think the Hope one must have been too deep, possibly - but something to check.
Posted : 01/11/2015 7:43 pm
Cannondale have odd head tube ID so you need a Cannondale KP205 headset. I got mine here:
http://www.cannondalespares.com/Cannondale-Tapered-Headset-1-1_8---1.5--KP205/product_detail/3-40184
It arrived in a couple of days, was easy to fit and works well. Seems pretty good quality as well.
Posted : 01/11/2015 7:49 pm
My Prophet has a fork with a 1.125" straight steerer and a normal Hope step-down. It's not a special Dale-only thing.
Posted : 01/11/2015 8:19 pm
Is what you need
This is what I run on my Cannondale (Trail sl) which is a true 1.5 steerer tube.
Posted : 01/11/2015 8:22 pm
I deleted my link as I did'nt see the Prophet bit.They have straight 1.5" head tubes so the hope will work.Later Cannondales had Integrated headsets (with plain bearings) which need the KP205.
Posted : 01/11/2015 8:24 pm
Thanks for the replies, that's saved me a headache working it all out. I know people have mentioned fork crown clearance issues when changing prophet forks. Will get on the hope website now.
Posted : 01/11/2015 8:33 pm
Might even be worth asking Hope, just to make sure.
Super annoying waiting for something to arrive only to find it doesn't fit!
Posted : 01/11/2015 8:43 pm
It'll fit. I have those exact headset cups fitted to a Prophet.
Posted : 01/11/2015 10:11 pm
[url= http://www.hopetech.com/wp-content/uploads/2014/03/HOPEHEADSETS2011Web.pdf ]Hopetech doc [/url]to confirm what Torso correctly says.
Yesterday I measured the old adapter that came out of my Prophet and it was bang on 49.70mm.
The lower F cup will be thinner than the adapter's 18mm but you should still have enough fork clearance. I certainly do with a RCT Revelation, albeit with a 1.125 step down.
Posted : 03/11/2015 4:56 am
