Somebody please help!
I have a 2009 Cannondale rize 130 and I am trying to fit a 2012 Fox 32 140 rl fork with a tapered steerer. Does a headset exsist that can do this? Surely it cant be that weird a combination? Seen posts that suggest headsets for 1/18" but none for 1.5" tapered.
Thanks in advance
All you need to do is change the top part of the headset to accommodate the 11/8" (I have an arcos one if interested that I used on my Cannondale prophet but only for 3 months so excellent cond £15 posted google them they are not cheap and very good quality)
The bottom part should work with your existing 11/2"
Email me at jonathantraverse@hotmail.co.uk
If you've currently got 1 1/8" straight steerer forks you can get Hope top and bottom headsets separately. So just get a 1.5" lower and use the existing top cup and bearing. Or if you current forks are 1.5" steerer just get the top cup.
[url] http://www.chainreactioncycles.com/Models.aspx?ModelID=70727 [/url]
come on arcos are a lot better than hope!
No experience of Arcos, but the Hope Step Down in my Prophet has been faultless.
Sorry guys my spelling is s##t
ACROS
No experience of Acros either 😉
If anyone reads this and needs a solution to the same problem I have found it!!
You need a KP205 from Qwerty cycles priced £42
Dropped straight in no problems
