Cannondale Lefty Ax...
[Closed] Cannondale Lefty Axle Dimensions
3 Users
I'm working on a 3-wheeler and require the dimensions of the Cannondale Lefty axle to integrate these hubs into the project.
Cannondale don't appear the most contactable of companies for help, the other chap I've tried is Tony Nunn - a specialist tuner in Bristol but his website is down and no answer on the phone.
Does anyone here know where I could obtain an axle? Perhaps you've an old axle you'd be willing to part with, or a bit of engineering nouse and a set of verniers to measure one up?
I've obtained the bearing sizes (6805-big, 6902-small), and an approximate (~65.3mm) distance between the outer edges of the bearings, so can work of this, but would rather have an axle to make sure.
Many thanks for any help.
Mike.
Posted : 01/08/2012 2:06 pm
If you post your location, a local might allow you to come and measure his axle... 😉
Posted : 01/08/2012 2:12 pm
Ooh er!
Cheers for the tip - I am in Malvern, Worcs but travel a lot so if anyone's up for that it'd be appreciated!
Mike.
Posted : 01/08/2012 2:28 pm
I'm up the road Stourbridge ways with a couple of lefty's, if you don't find closer...
Posted : 01/08/2012 2:32 pm
mikesingleton
I am in the same situation. I am also needing the dimensions for the Axel. Have you had any luck with getting the information. Mine is for a Velomobile Suspension I am working on.
Dave
Posted : 18/08/2012 11:33 pm
