Cane Creek Double B...
[Closed] Cane Creek Double Barrel - Bush and mounting hardware question...please help!
3 Users
My shock currently has 22mm mounting kit either end using the spherical bearing 'bush' set up.
My new frame downtube mount is 25.4mm wide so I need to change one end of the shock mounting kit.
My digital vernier calipers (and physical test) show that an ordinary Fox bush doesn't fit, so I can't fit a standard heavy duty mount kit. It would appear...
Am I wrong? Is there an easy, off the shelf, solution? My LBS's are not exactly supporting my quest very well!
I don't really want to get some new ends caps machined because over a certain shock mount width the advice is go DU bush and pin.
TF Tuned couldn't help.
I wanna ride my new frame!!!
Anyone help? Thanks!
Posted : 10/11/2010 8:47 am
Tried Stendec? They are the UK service people
Posted : 10/11/2010 8:48 am
good man, thank you, just called them and it's getting sorted on Monday!
Posted : 10/11/2010 9:10 am
BETD made some for me, due to the eyelets being odd sizes.
Posted : 10/11/2010 9:20 am
