Cane Creek DB inlin...
[Closed] Cane Creek DB inline on a Turner 5 spot
8 Users
Has anyone fitted a CCDB inline to a Turner 5 spot ? Does it fit with the the frame ok. I have seen other DW frames with them fitted with the air can at the bottom and CS lever near the main pivot, but i'm can't see whether there's room for the air can within the bottom DW link area. If it helps it's a 2011 frame.
Posted : 19/10/2014 9:19 am
Check out the Turner forum on mtbr, there's a ccdb inline thread.
Not much use to you but it fits by burner. If it fits yr 5 spot then don't hesitate to put one on. So much better than the fox shocks.
Posted : 19/10/2014 10:35 am
Bear in mind they have a maximum weight of about 80kg too. I was about to order one when I found out
Posted : 19/10/2014 10:37 am
No they don't chrisc777, according to TF Tuned they may lack some rebound damping when run at higher pressures. Mainly over the 210 psi i believe. I am 85KG with my riding kit on and again TF Tuned were very happy to sell one to me but not to a mate who is 95KG As his pressures would put him over that limit.
Also Cane Creek do not agree with this, there is a massive thread over on MTBR about it but i trust TF Tuned and am happy to take their advice.
Posted : 19/10/2014 10:45 am
Got a link to the mtbr thread mactheknife.Can't find the bloody thing.
Posted : 19/10/2014 10:52 am
[url= http://forums.mtbr.com/shocks-suspension/new-inline-double-barrel-cane-creek-913845-12.html ]MTBR Thread[/url]
I cant find the specific info about TF Tuned /Cane Creek after a brief read. I was sure i read it in here though. If in doubt give them a call 🙂
Posted : 19/10/2014 11:57 am
The info was in here:
http://singletrackmag.com/forum/topic/ccdb-inline-3/page/4#post-6352031
Posted : 19/10/2014 12:18 pm
We'll I'm under the 80kg so that one good point
Posted : 19/10/2014 12:22 pm
I have one on my 2011 Spot. Needed an offset bush at the bottom to miss the gusset. Really liking it, and halved the weight compared to my CCDB Coil. I'm about 85kg and have had no issues. TF have revised their original advice on weights.
Posted : 19/10/2014 12:36 pm
That's good new then, but at around 95kg it doesn't make much difference to me as I'm still out!
Posted : 19/10/2014 1:00 pm
I'd speak to CC direct for their view on weight limits
Posted : 19/10/2014 1:15 pm
Thanks mac.
Posted : 19/10/2014 2:16 pm
Flatlander,
That all sounds promising. Can i presume you have no issue with the offset bushing rotating. That maybe be a numpty question but i;m not sure how the bushing is held still.
Posted : 19/10/2014 7:42 pm
 poah
I'm 80kg run 170psi and have my HSR set to fully slow. 190x50 140mm travel.
Posted : 19/10/2014 8:16 pm
I got the offset bush from TF, it needed a little taken of the length (emery paper)to fit, but have noticed no rotation even after two weeks on alpine duty.
Posted : 20/10/2014 1:56 pm
Flatlander,
Which offset mount did lyou order from TF ?
Was it the 22x6 mm for the lower mount.
Also what size top mount do I need out of there heavy weight mounts?
I presume they use a 12.7mm bushing.
Posted : 27/10/2014 11:11 am
