Cane Creek DB Air I...
[Closed] Cane Creek DB Air IL and shock pumps....
5 Users
Can anyone confirm if the current RockShox pump fits the valve on the IL? My Fox pump won't fit as the connector is too short and fat so fouls on the air can before it engages the valve pin 🙁
ta in advance...
Posted : 24/07/2017 7:22 pm
I cant confirm that, but my x -fusion pump fits. I hope that helps
Posted : 24/07/2017 7:35 pm
 poah
It fits but very tight
Posted : 24/07/2017 8:27 pm
Thanks Poah, any idea on options that are a better fit?
Posted : 24/07/2017 8:31 pm
 poah
Not a clue, all I have are RS shock pumps so nothing else to try on dry sons IL
Posted : 24/07/2017 8:44 pm
Syncros might be worth a look.
Posted : 24/07/2017 9:53 pm
RockShox pumps only here and they fit just fine. You can release all the air and rotate the can to provide better access to the valve, the can is only held in place with a circumferential circlip and a rubber seal.
Posted : 24/07/2017 10:46 pm
