Can you use a tripl...
[Closed] Can you use a triple front deraileur on a compact doubel?
6 Users
I've got a GT Grade Flat Bar which I'm converting into a drop bar bike, but have a question about the front mech. Currently the bike has a triple chainset but I'm looking to put a compact double on there, my question is - could I adjust the limit screws on the front mech to make it work with the double?
Posted : 28/08/2017 8:49 am
Yeah, it'll work fine. Doesn't work that well the other way around.
Posted : 28/08/2017 8:50 am
Brilliant, thanks
Posted : 28/08/2017 9:01 am
I'd say it won't work fine. Sure it'll shift but not well, in my experience.
Posted : 28/08/2017 9:06 am
I have this on one of my bikes, and it works perfectly.
Posted : 28/08/2017 9:10 am
won't the chainring be too small for the mech?
like this spec: 44-38 tooth outer ring compatible,- if the cage is designed for a larger chainring, will the chain fall off more?
Posted : 28/08/2017 9:32 am
Usually i try to match the mech to the chainring sizes by using mtb mechs for combinations that are near to mtb sizes having said that plenty of cx racers with 105 mechs pretty versatile
Posted : 28/08/2017 10:15 am
The GT Grade comes with a road triple with a 50t chainring. A normal compact double has a 50t chainring.
Posted : 28/08/2017 10:18 am
That's what I was hoping for - I'm looking to swap out the Sora Triple for a 50/34 compact
Posted : 28/08/2017 10:38 am
