As title. Can you space down 150/120mm revs to 140/110 with a 10mm spacer?
For the sake of 10mm I doubt it's worth it tbh.
No but just put 10psi more in the - than the + chamber and it'll suck them down the 10mm your after
Cheers 😉
Whyte1 - Member
Dual Position Revs are solo air so that won't work. Just run them as is difference will be minimal
craigxxl - I were going to say that
they come supplied with plastic spacers though so I'm guessing they can be adjusted..
They usually come with a couple of 10mm spacers to insert in the air spring: whatever size spacer you add reduces travel and ride height by that much. Lots of instructions on web and on the SRAM site. I've found 15mm plastic plumbers pipe works a treat: just drill a couple of 2mm holes in it for air flow.
Dave
Appardntly its easy to nktice 10mm
It is when you only have 10mm to start with, you should know.
Aww bless.
