Can you shim a 30.9...
[Closed] Can you shim a 30.9mm seatpost up to 31.6mm?
4 Users
It would be a pretty slim shim, but is it possible?
Posted : 14/06/2012 11:59 am
You can indeed, I got one last week from here:
http://www.winstanleysbikes.co.uk/product/31366/USE_SS_309mm_Seatpost_Shims
Posted : 14/06/2012 12:03 pm
I have read on here in the past that some people just tighten them up further and blow the concequenses. However, if you are as OCD about this sort of this as I am I would recommend that you talk to an engineering tool supplier and get a sheet of 0.013" (0.35mm) shim steel sheet.
Posted : 14/06/2012 12:12 pm
Alternatively, do what hugelovitt says! 😀
Posted : 14/06/2012 12:13 pm
Yep - USE shim works great. It's a delicate thing though, so take care when fitting it.
Posted : 14/06/2012 12:14 pm
