Can you replace SRA...
[Closed] Can you replace SRAM 11 speed cassette cogs?
6 Users
 mrl
The outer cog on my SRAM XO 11 speed cassette has got a missing tooth. I remember reading somewhere that you can replace some of the bigger cogs. Is that true, if so anyone got and idea if where to get a replacement? Cheers
Posted : 15/08/2018 7:53 am
You can for Shimano :  https://www.bike24.com/p2177495.html
Not sure for SRAM
Posted : 15/08/2018 7:59 am
Hmmm, no part numbers in the SRAM spare parts lists, I suspect not.  That's annoying, I'm on my second 11 and 13 tooth sprokets on an my XT cassette.
Posted : 15/08/2018 8:08 am
It's just pressed on for the XX1/X01 cassettes.. OneUp Components do the X-Cog Sprocket replacement. I think Wolftooth may do an option also..
Edit: ah, did you mean bigger cog, or higher gear (smaller cog)?
Posted : 15/08/2018 8:11 am
Outer to me would suggest the 10t as inner is closest to the hub
Posted : 15/08/2018 8:16 am
 mrl
Sorry not very clear, it is the largest sprocket, think it is 42 tooth. Not looking to get a bigger range, just replace if possible. Found some expander rings but they all looked 10 speed.
Posted : 15/08/2018 8:20 am
As above, OneUp & Wolf Tooth make replacement aluminium cogs for the 42T ring. I swapped one on an XX1 cassette last year 🙂
Posted : 15/08/2018 8:32 am
 mrl
Ok thanks for the links but cannot afford that right now! Does anyone know of a steel or cheaper version. Happy to add a few extra grams.
Posted : 15/08/2018 8:48 am
