Can you remove a St...
[Closed] Can you remove a Stealthamjig without cutting it off the hose?
2 Users
I want to replace the frame grommet in my Whyte 909. I figured the easiest way is to thread the rear brake cable through the frame using the lever end, but can you remove the Stealthamajig without cutting the hose?
Posted : 26/11/2019 8:44 am
Yes, they just unscrew. The outer red 'olive' is a reverse thread, so clockwise to unscrew.
You only need to take off the red bit, the silver bit sits flush with the hose.
Posted : 26/11/2019 12:37 pm
It's been on there a while, so the red outer wouldn't budge. I ended up unscrewing the silver inner and the red outer came away with it. Shocked at the price of replacements!
Posted : 26/11/2019 12:44 pm
