CAn you reduce trav...
[Closed] CAn you reduce travel on bis deville fork
2 Users
As per the question I have a pair of 26" they are set at 160mm travel can they be reduced to 140mm?
Thanks
Richard
Posted : 28/09/2017 9:28 pm
Anyone help or done this ?
Richard
Posted : 29/09/2017 5:32 am
Yes the official way is with a 140mm air shaft plus spacer inside the damper unit. I might have one, otherwise it's probably possible with a 20mm spaced in the air side
Posted : 29/09/2017 6:07 am
Thanks
Posted : 30/09/2017 5:51 am
