any one help could I get reverb post to fit a rockrider 9.1 1full suss , or any other dropper post fit ? is it possible what would I need to buy .
Thanks Andy
Not a reverb. Gravity dropper, Ks lev (I think), TMARS and next year' Thompson are our main options.
You can use a 27.2 xfusion hilo with a 29.8 USE seatpost shim (Evans stock them)
Had my Rockrider 9.1 with this and worked well.
thanks , so I would need a 29.8 to 27.2 shim then ? would one of these work ,seen a ks lev dropper 27.2 .
Yes
http://www.evanscycles.com/products/use/shims-for-272mm-sx-posts--ec005387#select
All these shims are 27.2 internal diameter (which suit the 27.2 dropper post) so you would need the 29.8 one (external diameter) to fit the Rockrider frame.
