can you add a link ...
[Closed] can you add a link into a 10 speed shimano chain?
4 Users
and if so do you need to use the special connector pins, or can you use the existing rivets (like I always used to)
Assuming using the connector pins, I'd end up with 3 in the chain - does that matter?
alternatively - 2 sram style connector links
thanks
Posted : 17/10/2012 1:38 pm
you have to use a new pin.
3 pins isn't a problem.
2 SRAM ones are fine but they get a bit pricey as you can't reuse them.
Posted : 17/10/2012 1:40 pm
2 KMC connectors with a single inner link beteen them ?
Posted : 17/10/2012 1:44 pm
I've used a 9-speed SRAM quicklink in a 10 speed chain as a get me home measure. It worked fine for about three rides until I got my backside in gear and bought some proper 10spd links, with no noticeable draw backs.
Posted : 17/10/2012 2:27 pm
