Ideally for trail and road use so needs to go up to high pressures (120psi if poss?)
answers on a postcard......hyperlink even better.
Cheers 😀
I asked the same thing a few days ago.
This might help - http://singletrackmag.com/forum/topic/recommend-me-a-decent-trail-pump-please
I have one of these http://www.chainreactioncycles.com/Models.aspx?ModelID=42196 and I would give it 10/10 without fail, its excellent.
Lezine Tech superb.
epo-aholic,
You reminded me to pull my finger out and order one. I didn't go for the Micro Floor Drive in the end as mentioned in the other thread. I've just purchased this -
http://www.rutlandcycling.com/42376/Lezyne-Pressure-Drive-V2-ABS---Hand-Pump--Various-Colours-.html
Good size, great psi, and has the ABS system to avoid inadvertent valve core removal.
cheers guys, now ordered one......
The Lezyne ones look great but too pricey for my blood so went for the one motox2k recommended 😀
I got a Lezeyne one free when I subscribed to Dirt and it's one of the best I've used. Also got one of their mini track pups which is brilliant as well. And come to think of it I have their steel floor pump which is ace as well.
I can recommend you a trail pump...is that all you were needing?
