Can someone check m...
[Closed] Can someone check my work?
3 Users
So, based on the measurements form hope here:
and the 518 ERD from here
http://www.light-bicycle.com/New-26er-33mm-wide-enduro-MTB-all-mountain-downhill-carbon-rim-tubeless-compatible.html#.Uxmjl_l_tCg
I think this is correct, and I 64 250mm spokes should do the trick?
Posted : 07/03/2014 10:55 am
Yes, you've put the right numbers in the right places, and if you were looking at just even spoke lengths then 250s will be fine. But I'd definitely be waiting until I got my hands on the rim and then measure the ERD myself. I'd probably be happier measuring the hub too to be honest.
Posted : 07/03/2014 1:19 pm
Agreed. Didn't actually measure my rims, but all my spokes were too short when I used the manufacturers claimed dimensions, which suggest either American Classic or Light Bicycle aren't measuring things right!
Posted : 07/03/2014 1:22 pm
Ta both. Suspect I'd be less accurate than the manufacturer at measuring the ERD and hubs, to be honest.
Posted : 07/03/2014 1:42 pm
Have you seen this thread (and this post)?
[url= http://singletrackmag.com/forum/topic/light-bicycle-carbon-rims#post-5827578 ]http://singletrackmag.com/forum/topic/light-bicycle-carbon-rims#post-5827578[/url]
It's really not that hard to measure them - details here:
The problem usually is that manufacturer figures might be based on a prototype or pre-production version. Then things change without the published numbers being updated.
Posted : 07/03/2014 1:53 pm
