Can I run a Rocksho...
[Closed] Can I run a Rockshox Vivid spring on a Fox Van shock
3 Users
 Taz
I know the internal diameters are different - is this a problem?
Thanks
Posted : 26/10/2015 2:17 pm
IIRC RS are bigger ID, so won't sit on the spring collars properly and can subsequently rub on the body/piggyback. The spring is also a larger OD, so again chance of hitting the piggyback
Posted : 26/10/2015 3:35 pm
 Taz
Thanks HC - Yep I was wondering if there could be some fouling issues.
Posted : 26/10/2015 3:58 pm
Best to get the proper spring rather than the Vivid due to the OD being larger.
Posted : 26/10/2015 7:39 pm
What stroke and weight are you after ?
Posted : 26/10/2015 7:46 pm
 Taz
I have a couple of Ti springs for my Vivid. Before I consider changing to a Van (had one on loan whilst Vivid was serviced and I liked it but it may be my Vivid really needed serviced!!) I wanted to know if my springs could re used and now I know the can't I will likely not change.
Posted : 26/10/2015 11:17 pm
