Can i use cantileve...
[Closed] Can i use cantilever brake blocks on v brakes
3 Users
Can you use cantilever brake blocks with v brakes as I've made a mistake of buying cantilever brake blocks instead of mountain bike cantilever brake blocks.
Posted : 15/02/2018 12:55 pm
 JoB
depends
have you bought just the brake blocks or the whole blocks/holder/bolts units?
if the latter then you might be able to bolt them on, depending on the make of brake you're using, it's likely to be a bodge
if you've just got brake blocks then it depends, probably not as V-brake pads tended to be longer and thiner and fit a different holder
one of those 'We'll need to see pictures' or 'you'll just have to find out yourself' things
Posted : 15/02/2018 1:06 pm
Not if they're proper Canti brake pads, as they just have a metal rod which goes into a clamping nut on the brake caliper itself, rather than the V brake that just has the cut out for the threaded brake pad to clamp itself.
If that makes sense?
Posted : 15/02/2018 1:16 pm
