Can I use a sram ca...
[Closed] Can I use a sram cassette with Shimano STI shifters and 105 rear mech ?
6 Users
Can I use a sram cassette on Shimano STI shifters and 105 rear mech ?
what would the issue be ?
Are the internal drive profile the same to fit onto a hope free hub ?
Posted : 07/09/2017 5:27 pm
I have a KMC chain - which ive always used with Shimano also - but now want an 11-36 sram rear cassette.
Posted : 07/09/2017 5:30 pm
Issue would be your rear mech probably won't clear a 36T cassette.
Posted : 07/09/2017 5:33 pm
The Sram cassette will work perfectly with Shimano and KMC but as noted above, depending on your cassette size, 105 rear mech may not have enough length.
Posted : 07/09/2017 10:01 pm
yup. Is it 11 or 10 speed? If 10 speed then a 9spd Shimano MTB mech will work with your 10spd road shifters and the cassette.
Posted : 08/09/2017 11:34 am
it is 11 speed
Posted : 08/09/2017 11:36 am
Ultegra long cage RD-6800 defo works with SRAM11-36, so a long cage 5800 *should* work. If not, you'll need a goat link type thingy.
Posted : 08/09/2017 9:03 pm
richardthird - Member
Interesting, it's only rated for 32 max. What front chainring set up do you run?
Posted : 08/09/2017 9:10 pm
Compact and also on a 1x 38t. Also almost takes 11-40 Sunrace on the latter with a longer B-screw, but faultless with goat link.
Posted : 08/09/2017 9:13 pm
whats the goat link ?
I have a double cx set up - I will have to check the exact 105 rear mech I have
Posted : 10/09/2017 9:59 am
