Can I use a front b...
[Closed] Can I use a front brake mount on the rear
6 Users
Hi just wondering if it is possible to use a front brake mount on the rear break, because I'm looking for a rear mount for post mounting 203mm but can't seam to find rear for this size, only for front?
Posted : 01/03/2016 12:11 pm
Some mounts are universal - my Hope 183 post mounts do front or rear. I think it varies with the mounting (IS/post) and the caliper itself though.
Posted : 01/03/2016 12:24 pm
Don't rear mounts size down 20mm in relation to when they are used on the front?
i.e. a 180 front mount is a 160 rear.
Posted : 01/03/2016 12:27 pm
^^^^ what Ghostly says...
Posted : 01/03/2016 12:57 pm
So you'll need a 223 (?) front mount for your 203 rear (thats a masive disc, whats it for?)
Posted : 01/03/2016 2:33 pm
It depends on the frame. If the frame mount was for a post mount 160mm then the front adapter should work. iS style mounts are 20mm different as ghostly suggests.
Posted : 01/03/2016 2:37 pm
My Capra has 200mm front and rear ghost
Posted : 01/03/2016 3:39 pm
Ok thanks for the help
Posted : 02/03/2016 4:12 am
