Can I swap a 6 spee...
[Closed] Can I swap a 6 speed cassette for 7 speed?
11 Users
My knackered old pub/commute bike currently has some old shimano derailler on, indexed grip shifters and a 6 speed cassette.
The cassette is really too knackered now and needs replacing. In the box of spares I've got a partly worn 7 speed cassette, and it looks like there is room for it in the frame (bit of a gap between small cog and the frame where cog no 7 could fit).
But would the indexed shifters work with the change from 6 to 7 or not?
Posted : 08/11/2012 12:38 pm
yes - spacing is the same up to 8, I think
Posted : 08/11/2012 12:40 pm
Depends whether your 6-speed hub is Hyperglide compatible, i.e. can take a cassette with a lockring:
http://sheldonbrown.com/k7.html
Six-speed cassettes have a screw-on top cog, so the hubs don't always accommodate a lockring.
Also, cog spacing is different from 6- to 7-speed, so no, the indexing won't work:
http://sheldonbrown.com/cribsheet-spacing.html
Posted : 08/11/2012 1:43 pm
SP - WRONG! 6 and 7 speed have different spacing, 8 is slightly different to 7 as well.
If the bike is from post 1989 or so it will have a block not a cassette, and a cassette won't go on the hub. If it's a 6 speed cassette it may have a threaded top cog meaning a modern 7 speed cassette won't fit either.
In short...pics?
Posted : 08/11/2012 1:47 pm
Wow, more complex than I thought. Will post pics when I can.
Posted : 08/11/2012 1:56 pm
SP - WRONG!
I'm thinking of changing my username to exactly that
Ah, my 1st mtb had 7 - see how young I am ? (the 7-8 sp diff was trivial though wasn't it ? I def used the wrong cassette on a bike for a while before I got new shifters with no problems)
Posted : 08/11/2012 2:23 pm
http://sheldonbrown.com/speeds.html
It's all in here.
If you have 6 speeds it won't be a cassette. it'll be a screw on freewheel. Just get another off these off ebay, they're common enough.
Posted : 08/11/2012 3:46 pm
Yeah they did Uniglde which is different to Hyperglide. Then they did one that covered both. Then of course there was a 6 speed freewheel. Simples.
Posted : 08/11/2012 3:50 pm
Deffo did 6 speed cassttes, though did they use it for MTB?
Posted : 08/11/2012 3:52 pm
Yeah they did but I bet this isn't one.
If it IS and you can be bothered you could disassemble the two cassettes and use the sprockets from the 7 speed and the spacers from the 6 to build a new one.
Posted : 08/11/2012 3:55 pm
Yep, 1987-88 Deore and Deore XT.
Posted : 08/11/2012 6:17 pm
Yep, def did 6 spd cassettes. Got an nos one in shed 😉
Posted : 08/11/2012 6:50 pm
 joat
I'm sure the STW family can rustle up some parts for you. I cant think many have the need for that (servicable) old cassette lying in the scrap heap. I can't help BTW
Posted : 08/11/2012 7:56 pm
 JoeG
I'm going through this with a 1985 Ritchey Ascent. As I bought it, the freehub was locked up. The original 12-28 6 speed cassette was mangled, with bent and broken teeth. It was Uniglide (with the twisted teeth) not the newer Hyperglide with the shift ramps and teeth.
I had a Shimano 7 speed 12-28 cassette on hand. I took it apart and used a dremel tool to grind off the one wider spline that is used to index the cogs on a Hyperglide hub. I then used the 5 largest cogs along with the original 6 speed spacers (had to trim some little tabs off) and reinstalled on a new hub body. I bought a NOS Uniglide threaded small cog which holds everything together on the hub body. The 3 tiny bolts that hold the cassette together are just for convenience, and aren't really needed.
So its now 5 Hyperglide and 1 Uniglide cogs. Will try it on the bike today or tomorrow.
HTH.
Posted : 10/11/2012 6:02 pm
 JoeG
I mounted the 5 HG +1 UG cassette and it works just fine.
OP - I suspect that the biggest problem that you will come across is removing the threaded cog from your current cassette if it doesn't use a lock ring like current ones. Since the threaded cog has a right hand thread, the chain acts to tighten it every time that you pedal in that gear. Add to this years + water + dirt and they can be almost impossible to remove!
Posted : 12/11/2012 8:11 pm
top tip for removing stuck freewheel. Put the freewheel tool in the wheel, then clamp the tool also in the vice. Turn the wheel around the stationary tool = lots of leverage!
ps don't forget to turn the right way, otherwise you won't get anywhere!
Posted : 12/11/2012 8:37 pm
Wow, this takes me back to 1990-91 when I was using the old 6-speed screw-on Hyperglide freewheels with 6-speed indexed shifters for cheap, quality shifting. The Cannondale with that set-up got nicked 🙁
Posted : 13/11/2012 2:55 pm
6-speed hyperglide screw-ons existed in 1991? IIRC they were all UG.
6-speed was bomb-proof though.
Posted : 13/11/2012 3:10 pm
I did this,but was using non indexed downtube levers.
Posted : 13/11/2012 4:10 pm
Yeah, I was surprised when I looked into it at the time. These days, I consider 8-speed to be largely bomb-proof and will not upgrade until I absolutely have to.
Posted : 14/11/2012 11:28 am
