Can I reduce the tr...
[Closed] Can I reduce the travel on these Rebas?
8 Users
Hi all. I have a 2014 Reba RL 29er with 100mm of travel. I'd like to shorten them to 80mm travel. I know this is possible with my other (2011 ish) Rebas, but not sure with these. Cheers!
Posted : 05/10/2014 6:46 pm
pretty sure you'll need a new air spring, but other than that you should be ok
Posted : 05/10/2014 7:08 pm
Phone fisher the rock shock distributor and get through to the technical guys. They will tell you what you can do with the fork and more importantly will give you the part number for the correct air spring. I did this for my 100 mm rebas which I am going to change to 120mm travel by changing the air spring.
Posted : 05/10/2014 8:57 pm
Thanks guys 🙂
Posted : 05/10/2014 9:21 pm
'New Air Spring' sounds like a joke part. Are they kept on the same shelf as the tartan paint, next to the long weights?
Posted : 06/10/2014 11:25 am
It is possible and takes about 10 mins. You just need to swap to a different length airshaft.
I went from 80-100mm and have the part you need going spare. If your interested email in profile.
Posted : 06/10/2014 12:14 pm
If you technically capable, pretty much any air fork can be shortened just by extending the top out bumper (preventing it extending the full travel - in this instance by adding a 20mm spacer.
Posted : 06/10/2014 12:23 pm
[quote=nemesis ]If you technically capable, pretty much any air fork can be shortened just by extending the top out bumper (preventing it extending the full travel - in this instance by adding a 20mm spacer.
That sort of thing doesn't really work with newer RS forks because of how they balance the pressures in the +ve and -ve chambers. You'd end up covering the port that allows air between the two.
Posted : 06/10/2014 12:38 pm
 LoCo
Yes replace the air shaft, ~£25
Posted : 06/10/2014 12:41 pm
Cheers. Presumably this will also reduced the axle-crown height (which is what I'm really trying to achieve)? ie, unlike the Lefty which retains the same a-c when I insert spacers to reduce travel.
Posted : 06/10/2014 2:57 pm
