Can i get replaceme...
[Closed] Can i get replacement seals for a shimano calliper?
6 Users
At the minute the front brake is not working well, lots of air in it and i cannot see to bleed it. Trying to eliminate issues it could be a seal issue in the calliper (amongst others)
Is there anywhere i can get the seals from or is it new calliper if thats the issue?
Posted : 20/11/2012 8:44 am
Unless things have changed recently, you cannot get seal kits for Shimano brakes.
Posted : 20/11/2012 8:48 am
No. You have to buy a whole new calliper. Same for Magura as well
That said, if its not leaking, you don't need new seals.
Posted : 20/11/2012 8:55 am
But air is getting in somewhere
Posted : 20/11/2012 9:11 am
Take pads out
Put an 8mm allenkey in the gap
Pull brake hard and hold
Youll see bubbles round the piston if they are weaping.
Posted : 20/11/2012 9:28 am
Take pads out
Be very careful doing that. I've blown a piston seal that way.
Posted : 20/11/2012 9:59 am
right - elimination process starts tonight. When i stopped yesterday the lever end was popping very quietly
Posted : 20/11/2012 10:22 am
nothing leaking and all feels good for now - how does air get in?
Posted : 20/11/2012 6:46 pm
i *think* the lever is sucking air in where the olive/insert is
Posted : 20/11/2012 6:56 pm
What calliper is it I fitted some Hope mini seals into an XT M775 and ran it for nearly 2 years fine, it did change the feel of the brakes slightly though.
The calliper was done anyway so I took the chance on a £6 pair of seals.
Posted : 20/11/2012 7:03 pm
Think its sorted 🙂
Posted : 20/11/2012 7:14 pm
