can i fit tapered f...
[Closed] can i fit tapered forks to a non tapered head tube??
11 Users
As title really Im looking at getting some new forks for my pitch and most of the good deals are with tapered forks??
is there a headset conversion or something that will allow me to fit this type of forks??
cheers
steve
Posted : 07/12/2011 8:45 pm
No.
Posted : 07/12/2011 8:46 pm
Maybe.
Forks tapered 1.5" to 1 1/8 will fit in non-tapered 1.5 headtube (with an adapter at the top) They won't fit into a 1 1/8" headtube though (unless you use an inverse shim)
Posted : 07/12/2011 8:49 pm
 jedi
no
Posted : 07/12/2011 8:50 pm
the answer is yes if its a 1.5" headtube
Posted : 07/12/2011 8:59 pm
ah pish !!! back to the drawing board then....
im after a set of 150/160mm air forks normal steerer and 20mm front hub.....
suggestions please, new or used !!!
Posted : 07/12/2011 9:00 pm
 jedi
a pitch aint 1.5
Posted : 07/12/2011 9:04 pm
Revelations have been superb on my five, 20mm maxle and air + and neg. Survived a battering at home and abroad.
Posted : 07/12/2011 10:27 pm
I thought you could fit one to an internal headtube with an adaptor headset thingy.
Posted : 08/12/2011 12:03 am
cant you have the 1.5 steerer pressed out and a 1. 1/8 one made up and pressed back in, as you say some stoming deals on the tappered type, money saved could go towards that, of course use a good eng comp 😀
Posted : 08/12/2011 12:10 am
I have a tapered headtube 🙂
Where are these storming deals???
Posted : 08/12/2011 5:10 pm
Right here!
As long as you want some 180mm RS Domain 318s in white 🙂
Posted : 08/12/2011 5:30 pm
http://www.ebay.co.uk/itm/2011-FOX-FLOAT-32-SERIES-RLC-FIT-MTB-FORK-15MM-AXLE-150MM-TRAVEL-/360415550506?pt=Cycling_Parts_Accessories&hash=item53ea70dc2a
I just ordered some 160mm tapered vans from the same seller so I will let you know when they arrive, if you were interested in ordering from him. Sam
Posted : 08/12/2011 5:39 pm
