As above really, I know they just use spacers, an I can just open them to check, but hoped someone on here might know?
Thanks
This doc suggests not
Page 24/25. Though it also doesn't seem to show a set the same as you have for sale. THe straight 27.5 boost is shown as 140-170mm travel while the 27.5+/29 covers 100-140mm. Page 25 shows two base lengths for IVA forks but to me that doc is unclear if those choices apply only to 26". Either way 120 and 160mm are not on the same base length.
THe product page sugggests not as well (under key features); https://hayesbicycle.com/collections/forks/products/mattoc-comp-27-5-160mm-travel-matte-black-1-5-taper-w-vtt-damper-boost
Thanks, they're OEM so may be different, I'll open them up just to check. As they're brand new I was trying to avoid doing that though.
