Can a tubeless tyre...
[Closed] Can a tubeless tyre become unsealed & how?
6 Users
I needed to add sealant to my tubeless mtb tyre. The valve core isn't removeable, so I took a the tyre partly off the rim, added 80ml and reattached the tyre. I re-inflated the tyre to 50psi (tyre says 35-58psi). Air & sealant began to leak at the presta valve hole. I spun & shook the tyre for 5 minutes, when the leak stopped. It seemed to hold. When I got up today, it was flat. I repeated the process and air & sealant began to leak out at the valve hole again.
Funny thing is, it was holding air before I added sealant. Why did this change? Maybe I moved the valve very slightly when I attached the pump? It's a Lifeline track pump with a booster chamber and a lever for locking on to the valve.
The wheel was bought new as tubeless, not converted later. I have successfully converted other wheels using valve & rim strip, not tape.
Posted : 30/04/2021 12:50 pm
Let there be life.
Posted : 30/04/2021 2:22 pm
The valve may well be a little loose, possibly the tyre hasn't seated properly etc.
Best bet by far with tubeless is get it holding air then go ride it for a bit. Shaking etc is all well and good but nothing compared to five minutes of hoof printed bridleway.
Posted : 30/04/2021 2:28 pm
Maybe you dislodged the rim tape when breaking the tyre bead and air is getting into the rim.
Posted : 30/04/2021 2:30 pm
 igm
tthew +1 for my money
Posted : 30/04/2021 2:37 pm
Yep, generally compromised rim tape.
This seems to effect road wheels more than MTB wheels for me
Posted : 30/04/2021 2:39 pm
I will try taking it for a ride. If that doesn't work, I will use the rubber rim strip & valve all in one. "Cheating", perhaps but I have found them to be easier to use than the tape.
@dangeourbrain thank you for explaining how to access this thread after I started it.
Posted : 30/04/2021 3:01 pm
@erinquinn 's quite alright.
It's community service after [unawares of the new features] I moaned at someone for bumping their own thread a few days ago 😂
Posted : 30/04/2021 3:18 pm
... I will use the rubber rim strip & valve all in one....
They were generally for converting non-tubeless rims to tubeless and worked well for that. If you put them on already tubeless rims the extra thickness of the rubber, compared with a wrap of tape might make seating tyres problematical.
Posted : 30/04/2021 4:18 pm
I'd also recommend swapping to valves with removable cores - makes adding sealant a doddle and would avoid such issues in future.
Posted : 30/04/2021 5:04 pm
