can a hope xc be co...
[Closed] can a hope xc be converted to 20mm?
9 Users
well?
Posted : 20/10/2009 8:22 pm
nope. well certainly didnt used to be able to. need a bulb... or a pro 2.
Posted : 20/10/2009 8:23 pm
yes
Posted : 20/10/2009 8:26 pm
terry - serious?
Posted : 20/10/2009 8:28 pm
Not according to Hope.
I'm all ears though.
Posted : 20/10/2009 8:29 pm
thats good because showerman is all shite
Posted : 20/10/2009 8:30 pm
Couldn't be when I asked Hope.
Posted : 20/10/2009 8:33 pm
it cant. the OD of the bearings aint much bigger than 20mm...
Posted : 20/10/2009 8:53 pm
Nope.
The ID (bore) of the 6001 2RS bearing is 12mm; so bearing in mind that the OD is only 28mm...
Posted : 20/10/2009 9:09 pm
see... 28mm OD. would be shit all bearing that you could fit in that gap...
Posted : 21/10/2009 10:05 am
"would be shit all bearing that you could fit in that gap... "
you could try to find some bushings to fit .. what could go wrong?!
Posted : 21/10/2009 10:37 am
Pro 2 bearings aren't much bigger. And yes, they can be a bit cack.
Posted : 21/10/2009 10:40 am
you could try to find some bushings to fit...
Who needs bushings? A few rounds of teflon tape should do the trick... 😉
Posted : 21/10/2009 10:53 am
You could probably convert to 15mm through axle ok, if you can find the right size bearings, but 20mm would be a squeeze.
Posted : 21/10/2009 10:57 am
ha ha. for all my jesting, my pro 2 does indeed feel like a hope xc with the bearings punched out and the axle just loose inside.. talk about play. the bearings last about 3 weeks for me...
Posted : 21/10/2009 10:58 am
You could probably convert to 15mm through axle ok, if you can find the right size bearings...
Good thinking; 6001 bearings are 12 x 28 x 8mm - 6902/61902 bearings are 15 x 28 x 7mm... 1mm thinner.
Posted : 21/10/2009 11:05 am
