Can a Fox float DPS...
[Closed] Can a Fox float DPS Evol 200x51 be changed to get 200x57?
6 Users
I've got the 200x51 but the shaft is 57mm long. Can this shock be changed to 200x 57 internally so I can use it on a longer travel bike?
Posted : 28/05/2017 10:40 am
Yes it can be but it would need stripping down to do it and a new part fitting.
Posted : 28/05/2017 11:02 am
That's cool.
What internal part would I need?
Posted : 28/05/2017 12:48 pm
A new bearing housing which to fit requires a partial strip down and rebuild.
Posted : 28/05/2017 12:50 pm
Any idea how much that'll cost? Dies the same apply for the new x2 do you reckon?
Posted : 28/05/2017 5:38 pm
I believe it would be a specialist job so I would ring tftuned / mojo or some other specialist company
Posted : 28/05/2017 9:18 pm
is the new part necessary expensive?
Is it the same for RP23?
Posted : 29/05/2017 8:20 am
Its the same for all fox shocks of that eye to eye length.
Posted : 29/05/2017 9:09 am
Is it the shaft only?
Posted : 29/05/2017 10:59 am
Jon you been buying secret upgrades !!
send it to rick he will sort you out 😉
Posted : 29/05/2017 3:46 pm
I see now that the bearing housings are different on the 51/57 rp23
However, the damper shaft, internal adjuster rod and damper body are all different lengths too
So will work if I just swap the bearing housing, or have I missed something?
Also, if this does work, what effect will it have on the compression/rebound ranges?
Posted : 08/06/2018 1:59 pm
Nothing to do with me but if it's taken a year to get this far alric this just appeared in the classified and might be serendipity.
https://singletrackmag.com/forum/topic/fs-fox-float-ctd-4/
Posted : 08/06/2018 2:30 pm
hoho
its been a long year, but I'm inclined to stay away from CTD after reading a couple of criticisms. Last year
thanks anyway
Posted : 08/06/2018 11:18 pm
