Camber Mavic Wheel ...
[Closed] Camber Mavic Wheel Help
2 Users
Is there a method of getting Mavic C29ssmax wheels to fit the 12mm bolt through on the back of a camber 29er? Thanks
Posted : 09/11/2012 9:34 pm
Thought they came as 142 x 12 , if not they do adapters for 142 x 12 rear . You will also need an adapter for the front as they come with a 15 mm bolt through and your Camber will have a standard 9mm Q/R .
Posted : 09/11/2012 9:51 pm
Just found this:
Axle:Aluminium 9 x 135
Does that mean im knackered??
Posted : 09/11/2012 9:59 pm
