Anyone used the above? Have had it in my back pocket for the past couple of races but luckily not had to use it yet, at £8.99 a pop don't really fancy testing it out on the trail. Am I going to be let down or pleasantly surprised?
I have used the stuff for the past couple of years and get on really well with it. Only once got a puncture that didn't seal but that was a pinch right at the rim bead.
Used it in my Nevegals on Stans and it didn't last too long (a couple of months) before the whole tyre started to leak around the rim. Switched to Stans which is holding air much better.
I've used it a lot and like it, much simpler and cleaner to used than stans because you can just squeeze it in through the valve stem, which also makes it good for using in tubes where necessary.
