Cabling up a road b...
[Closed] Cabling up a road bike..... Any tips please.
7 Users
Im currently building up a road/cross bike and the next job is to add cables for shifters and mechanical disc brakes. Once this is done I can tape up the bars.
10 speed Tiagra shifters and TRP Spyres brakes.
Do you have any hints or tips on doing a professional job and making it easier for myself.
Thanks
Steve
Posted : 25/11/2019 1:51 pm
Use compression less outer for the brakes they will feel 100% better than standard spiral cables
Posted : 25/11/2019 2:17 pm
Follow the smoothest line from the lever to the stays that you can. Make the gear outers the same length on L and R sides. Cross them over so the LH lever cable goes to the RH frame stay and vice versa.
Hold the cable outers in place on the bars with electrical tape; then you can wind the bar tape over the top.
Posted : 25/11/2019 2:23 pm
Also, make sure the entry and exist for the outers are properly round and not crushed. You may need a file/grinder for the brakes. For gears, I poke them through with a cable and then open the hole up a little with a small nail.
Posted : 25/11/2019 2:24 pm
Cheers. Ive bought the TRP outer fro disc brakes so hopefully will make the brakes feel good .
Posted : 25/11/2019 2:48 pm
If you ever plan to travel with the bike in a box make sure the cables are long enough. Crossing over usually allows for this.
Posted : 25/11/2019 2:49 pm
YouTube videos.
Posted : 25/11/2019 4:21 pm
An old spoke is the perfect tool for fishing the cable end out of the port under the BB when you are trying to feed it through the frame.
Posted : 25/11/2019 4:22 pm
If it is internal cabling then just buy the Park kit - it's expensive but when I think of the hours I've wasted...
Posted : 25/11/2019 7:17 pm
