Cable Separator Cli...
[Closed] Cable Separator Clip
6 Users
I have just built up an Anthem and remember seeing somewhere on here a photo of a clever setup that went between the two cables that run either side of he shock, holding them away from the shock itself a little. It was a rod with a clip either end. Does anyone know what these are called and where I an get one?
Many thanks,,
Dom
Posted : 21/09/2013 10:32 pm
I'm sure I saw something like that in the Rose catalogue recently.
Posted : 21/09/2013 10:38 pm
I've got one I could post you
It's off a specialized but made by jagwire, about 75mm long, single plastic part
Posted : 22/09/2013 6:22 am
You can make your own with a piece of windscreen washer/fishtank tubing cut to size and a long thin ziptie threaded through, round one hose and back on itself again so it holds both cables/hoses against the ends of the tube.
Posted : 22/09/2013 9:49 am
Excellent suggestions. Thanks!
Posted : 22/09/2013 11:24 am
You can get the cable clips that come with a Reverb off of ebay. I use them to keep brake anf gear cables tidy
Posted : 22/09/2013 11:39 am
Have you got a link please? I was looking for some on Ebay earlier and couldn't see any.
Posted : 22/09/2013 11:53 am
Sorted! Found them on eBay after looking them up on the Jagwire site. (Thanks petefromearth)
Neninja-here's a link to the Jagwire product. You can then search on eBay. The part is called a housing holder.
http://jagwire.com/products/v/S-Hooks_Bridge
Thanks again for all your help,
Dom
Posted : 22/09/2013 2:08 pm
