Cable routing HELP
[Closed] Cable routing HELP
3 Users
 Pook
Ok, so I've built a bike today. All the cables run over the top of the cross bar, where there are 3 pairs of cable guides, one for each of the gear cables, one for the rear brake.
In routing the cables I've got in a bit of a tangle, things run smoothly, i can move the bars freely, but it just doesn't "look" right if you know what I mean.
I'd take pics but i don't have my camera. Do any of you lot have any routing pictures you could stick up showing how you've sent the cables round the frame?
tia
Posted : 14/02/2009 6:48 pm
Route the cables on the opposite side on the tube to the position on the bars, if you know what I mean.
I think
Posted : 14/02/2009 7:09 pm
 Pook
tried that, it just resulted in them crossing over weirdly on the crossbar. I know it should be simple, but something just isn't working right!
Posted : 15/02/2009 10:00 am
i hate messy cable routing (and don't even get me started on how long some bikes have their front brake hose)
rear brake hose = from lever into guides on left hand side of frame.
rear mech cable = from shifter to centre guides without going round the stem/headtube
front mech cable = from shifter round head tube to guides on right hand side of frame.
run it that way on both mountain bikes with top tube routing (old clockwork =above the tube guides, sanderson life, below the tube guides)
on the scott which has routing on/under the down tube i run
rear mech cable = from shifter round head tube to guide on left crossing to guide on right at bottom of down tube
front mech cable = from shifter round head tube to guide on right crossing to left hand side of frame at bottom of down tube.
work fine look neat
Posted : 15/02/2009 11:46 am
