Caad8 replacement c...
[Closed] Caad8 replacement cassette advice
5 Users
Think my cassette has had it and looking at a replacement. Would be grateful for some advice please from the resident mechanics!
Is this a like for like replacement? Could it be anything other than 9 speed?
There's two chain rings on the front (compact?).
Is 11-30 the norm?
[url= http://www.chainreactioncycles.com/shimano-tiagra-hg50-9-speed-road-cassette/rp-prod387?_$ja=tsid:46412%7Ccgn:Shimano+-+Cassettes%7Ccn:Chain+Reaction-UK-PLA-PLA-All-DT-SE%7Ckw:376538UK_Shimano+Tiagra+HG50+9+Speed+Road+Cassette&gclid=CNjz0OTa7LoCFfMctAodJhsArA ]9 speed tiagra[/url]
Any reason I couldn't put a 105 on and save a bit of weight:
[url= http://www.chainreactioncycles.com/shimano-105-5700-10-speed-road-cassette/rp-prod50454?_$ja=tsid:46412%7Ccgn:Shimano+-+Cassettes%7Ccn:Chain+Reaction-UK-PLA-PLA-All-DT-SE%7Ckw:179231UK_Shimano
+105+5700+10+Speed+Road+Cassette&gclid=COvS6era7LoCFWUOwwodaz0AKg]105 9 speed[/url]
Posted : 17/11/2013 9:00 pm
If it is older 9 speed Tiagra, then it should be 50/36 and have a 12-28 on the back for compact gearing. You'll need another 9 speed cassette because 9 and 10 speed are not compatible. If it is a newer CAAD8 and the Tiagra shifters have windows with indicators for gears, then it is 10 speed and any 105 cassette will be just fine, including 105.
I would suggest a 12-25 10 speed cassette unless you ride some serious hills on long rides. 36/25 will get you up most hills in the UK as a one off. And you will need a new chain.
Posted : 17/11/2013 9:15 pm
Might it be easier/more accurate to count the number of sprockets, and what size they are, than ask online without even saying what model/year the bike is?
If it's much worn then you'll need a new chain too.
Posted : 17/11/2013 9:41 pm
Thanks both!
It's a 2011 CAAD8, R501 Shimano Wheel.
(The problem started when it fell apart on a ride yesterday, I thought originally it's worn, but I think now I just fitted it really badly...)
I counted nine chain rings, with 27 teeth on the big one and 12 on the small one.
Is it right that the lock ring screws into the hub? If so, I think the problem is that the cassette extends further than the hub, so it can't screw in properly. I don't know what was going through my head when I put it on, I've done a fair few miles on it before it exploded!
Am I putting a square peg in a round hole, or should this cassette go on? If so how?!
Here's some pictures, hopefully it makes more clear:
https://picasaweb.google.com/104061892447017957979/Cassette?authkey=Gv1sRgCJCm1qOF_a3idA&noredirect=1#
Posted : 18/11/2013 7:47 pm
Could you explain "exploded"? And I could be wrong but is the 12 tooth on the pile the wrong way round? So the spacing is wrong?
Posted : 18/11/2013 7:52 pm
I was standing up on the pedals going up a steep hill and it came undone!
Posted : 18/11/2013 7:54 pm
I could well believe the spacing is wrong...I'll see if I can find a guide to indicate the right spacing and see if that helps...
Posted : 18/11/2013 7:55 pm
It says CS-HG50-9 on the lock ring. So perhaps this is the diagram?
Posted : 18/11/2013 8:10 pm
Ok, I've got it on but when I turn it to tighten up it feels like it's grinding. Ie, I can turn to tighten and feel a grinding of notches.
Any advice welcome!
Posted : 18/11/2013 8:34 pm
That's exactly how it should feel. AS long as the cogs are evenly spaced and you don't apply stupid amounts of torque, you'll be fine. For a replacement, you will need a 9 speed cassette. That rules out 105.
Posted : 18/11/2013 9:21 pm
The lockring and last sprocket are serrated so they lock together to keep it done up without using massive amounts of torque.
Posted : 18/11/2013 11:08 pm
