Buying brakes from ...
[Closed] Buying brakes from the Germans
12 Users
Help me think this through! I'm about to hit buy on a set of Zee's from the Germans. I assume they'll come the wrong way round. But as my frame has internal routing, that doesn't actually matter coz I'll need to disconnect bits to fit them anyway?
Is swapping the hoses round fool proof? I'm prone to c0cking things up like this!
Posted : 01/03/2019 9:15 pm
It's extremely simple to do. Shortening them at the same time is equally so.
Posted : 01/03/2019 9:23 pm
Hoses are easy if you have bleed kit and a spare olive or two if shortening. I did once distort a Shimano olive so if you're prone to cock ups a couple of spares on the order might be worthwhile.
Just make sure the delivery date is before 29th March.
Posted : 01/03/2019 10:38 pm
Got some Deores from them, ham-fistedly swapped and shortened hoses easily enough, thankfully no internal routing though so couldn't comment, think if you re-route the cables BEFORE shortening them, then any minor fluid loss wouldn't be a problem as you can just cut the hose back beyond the empty end of the hose, if that makes sense...
Posted : 02/03/2019 10:23 am
Any particular Germans ? I'm after some new twin piston jobbies .
Posted : 02/03/2019 10:43 am
It’s extremely simple to do. Shortening them at the same time is equally so.
Yes. If you do it for the first time have a look at youtube. I'am sure there are plenty good videos how to do it.
Think new Shimano olive always is included in the brake package from Shimano. Bleeding and new oil filling is a bit of a mess so....
Posted : 02/03/2019 10:49 am
Missed opportunity for a pun involving Zee Germans.
Posted : 02/03/2019 11:06 am
The only issue with shortening, internally routing and  and swapping hoses at the same time is that you're more likely to flick, knock or in some other way lose more oil from the lever/hose than if you do one at a time as you'll have 2 hoses flapping about rather than one.
It's always worth doing a bleed when new with shimano brakes even if you don't shorten/swap hoses as i have found air in them on more than one occasion.
Posted : 02/03/2019 11:13 am
I got a 4pot caliper from bike-discount.de and was squealing and wouldnt stop quick on mylast ride.
I just cleaned it and going to test it, but wondering what happens if I need to send it back.
Are there many cases of pistons leaking tiny amounts of oil with 4 pots, like there were with 2pots?
Posted : 02/03/2019 12:13 pm
I had a painless warranty return with B-D. Free return postage too. Not a caliper though.
Posted : 02/03/2019 1:31 pm
Any particular Germans ? I’m after some new twin piston jobbies
Bike discount. I've used them before so I'm happy with the service etc
I've hit buy. Should be a fun evening when they show up......
Posted : 02/03/2019 3:19 pm
Snap! Ordered exactly the same today. Need to route front through steerer on trials bike so same. Was hoping they might be like the SLX i got a while back that were not connected to levers but website says they're ready to roll.
Posted : 02/03/2019 5:40 pm
You may have glazed the pads. Try rubbing the pad braking surface on some sandpaper then follow the bedding in procedure again.
Posted : 02/03/2019 5:52 pm
