Bushnell EBB - stuc...
[Closed] Bushnell EBB - stuck?
3 Users
 tor5
Trying to remove what appears to be a Bushnell EBB from my Chumba HX1 and it appears to be stuck. I've loosened the allen bolt until it goes tight then seems to free off again but I can't seem to the ebb to actually move.
anyone got any bright ideas? Do I need to go loose, tight, loose or loose, tight, loose, tight? Think I might need to sit down and figure this out with a decent ale and plenty of time!
Posted : 12/02/2014 11:15 pm
Tap the allen bolt to free off the wedges, then tap the outer shell of the bushnell EBB, i have one fitted to my Salsa Juan Solo.
Posted : 12/02/2014 11:16 pm
Much as above a little tap always frees off mine also in a jaun solo
Posted : 12/02/2014 11:19 pm
Even if you do figure it all out and have plenty of time to hand, I tend to always have a beer close by when i'm working on my bike as it often helps the thought process, then again i do tend to work on my bike on the stand in the living room.
Posted : 12/02/2014 11:23 pm
