Budget Replacement ...
[Closed] Budget Replacement gear and brake cable for Shimano 105
5 Users
Hi I think my road bike is seizing up whilst on the turbo trainer - the levers are catching each other when changing. A thread on here a few days ago suggested sticky cables.
In an amazing moment of foresight I thought I would watch some GCN videos, order the cables and replace in time for the glorious lock down free spring riding (and avoid home schooling). After a search online I was bamboozled by the amount of Shimano replacement kits, prices and out of stock. It looks like Wiggle and Amazon have some kits available but what is the minimum quality / price I can get away with for long lasting slick shifting?
Thanks (sorry for naive new roady question, I do know if it was my mountain bikes I would just Jagwire and it would last for years)
Posted : 17/01/2021 7:07 pm
Clarkes stainless are cheap and good. Planet X
Posted : 17/01/2021 7:15 pm
 Bazz
As above, Clarke's, Halfords is usually well stocked.
Posted : 17/01/2021 7:29 pm
Wiggle lifeline stuff is good for things like this. I've been impressed with their performance stuff which often comes in the same price as everyone else's standard.
Posted : 17/01/2021 8:01 pm
If you want to do the outers as well as inners then the Shimano kits are good, and good value- and then once you've got everything going nicely, in future just use stainless inners
Posted : 17/01/2021 8:03 pm
Thanks all. Northwind is that polymer coated Shimano outers?
Posted : 18/01/2021 10:03 am
Sorry another dumb question. I went with the Shimano kits with polymer coating. Brakes all good and rear derailleur cable changed so far without hiccup, other than a sheared pinch bolt on the rear mech.
But both the existing front and back gear cables have exposed sections which at points have a thin plastic piping covering them. This was welded solid to the rear cable and had gone sticky on the outside so i can see why the changes were sticky. Should this be replaced ? If so there was none in the kit, any ideas where can I buy some ?
Thanks
Posted : 01/02/2021 6:37 pm
Amazon for the PTFE liner. I'll go check my orders as I bought some for under the BB shell on my refurb project.
Posted : 01/02/2021 7:15 pm
