BTP car cuts up cyc...
[Closed] BTP car cuts up cyclist
34 Users
Apologies if this has been done
Posted : 15/09/2014 6:41 pm
Not sure theres any real safety issue there?
Posted : 15/09/2014 6:43 pm
Doesn't look too bad to me.
Agree it's not too close (I've recently been buzzed by two of 'em a lot closer) but you can bet your arse that if they were behind a driver pulling the same maneuver they more than likely would've given them a tug, at the very least to give them a bollocking.
Posted : 15/09/2014 6:46 pm
Not the best road craft by either party
Posted : 15/09/2014 6:57 pm
This.
However, one is a public servant charged with upholding laws and standards. And one is a chap on a bike.
Posted : 15/09/2014 7:00 pm
Eh? How's the cyclist in the wrong at all? He's clearly over to the right so be can get in the correct lane and not get punted down to the left. Police car is clearly an impatient cretin already moving forward before the lights even turned.
Posted : 15/09/2014 7:01 pm
If that was the worst that happened in a month of commuting, I'd be pretty chuffed.
So as long as the police behave better than the worst road users, crack on?
Posted : 15/09/2014 7:07 pm
Maybe someone had had a really bad day, and made an error of judgement that proved to actually be quite safe, if unwise.
Sometimes the height of the horse affects perception? 😉
Posted : 15/09/2014 7:09 pm
That is smack outside my work . It is a lousy junction for cretins particularly when one comes in from the right on that camera angle.
The cyclist appears to be in the correct position and does nothing wrong.
Posted : 15/09/2014 7:11 pm
It's not the worst I've seen but thought I'd pop it up I on here after it appeared on Facebook. From the looks of it that middle lane can go either way at the split ahead which is why the cyclist was across to the right of the lane. If it was me driving I'd have waited behind the cyclist to see what he was doing before going round him.
For me it's all about setting an example and the person driving that car doesn't set a very good one at all.
Posted : 15/09/2014 7:12 pm
I can tell you exactly what's happening there , if you don't gun the engine from that junction you usually hit a red light about 400 yards from where the video starts. However it seems nowadays everybody in the centre of Leeds drives like this(also why I only ride mountain cycles off road now)
Where should the bike be then to get to the left of the lane he wants?
Posted : 15/09/2014 7:13 pm
Cyclist holds his line, driver goes around without forcing anyone else to change direction or speed.
Posted : 15/09/2014 7:14 pm
I actually think that was pretty p-poor of the police there.
Looked like he was edging into the box before the green
Then he under takes
Then he cuts cross chevrons
Cyclist would have been better off sitting over to the left but still no excuse to drive like that. Someone positioned badly in front of you does not give you the excuse to drive poorly too.
edit: looking again I'm not sure the cyclist was that out of position. That middle lane seems to have the option to take lane 2 or 3 at the split. Cyclist knew he wanted lane 3 and doesnt really cut much over to the left after the car passes.
Pretty sure you would fail your driving test for doing that.
Posted : 15/09/2014 7:16 pm
Except you don't hit a red light unless you gun it, watch the video on to the end even the cyclist gets to that light on green .
Posted : 15/09/2014 7:25 pm
yeah hence why my post says USUALLY
Posted : 15/09/2014 7:34 pm
Not the best but a possibility is that he was just starting a response run and his lights had failed - wanted to nip round. He /she didn't put the bike in danger though.
Posted : 15/09/2014 7:42 pm
Cyclist would have been better positioned in the middle of the central lane. Instead of positioning himself to the right then cutting across to the left. From his original road position I would have assumed he would be going into the right hand lane. Doesn't excuse the police driver for their crap driving.
Posted : 15/09/2014 7:56 pm
BTP you say...bet the real police wouldn't have done that.
Posted : 15/09/2014 8:00 pm
I know that junction well, and that's pretty much where I'd position myself on a bike if I was going that way. I wouldn't be delighted at a driver doing that either, but as some have said, if that was the worst driving I had to contend with on a commute, I'd be delighted.
Pretty poor for a police officer though, even the BTP.
Posted : 15/09/2014 8:12 pm
total dick move by the car. end of.
Posted : 15/09/2014 8:47 pm
...but you can bet your arse that if they were behind a driver pulling the same maneuver they more than likely would've given them a tug, at the very least to give them a bollocking.
Not unless that driver was driving a train they wouldn't.
Posted : 15/09/2014 8:55 pm
I know that junction and tend to sit in the middle of the lane to avoid that sort of move. Have seen much worse than that one though!
Posted : 15/09/2014 10:06 pm
Heh. I see where I went wrong there...
Posted : 15/09/2014 10:42 pm
 aP
The BTP doesn't cut the cyclist up, (he) does anticipate the lights and "drive enthusiastically". Just ask yourself, "what would surfmat do?", after all most of you IT guys drive Audis, willy wave about how fast you drive on country roads and need 400+hp to drive to the shop formerly owned by Dame Shirley Porter.
What I'd be much more annoyed about is how awful those roads appear to be, and how they appear to have no facility for vulnerable road users.
Posted : 15/09/2014 10:50 pm
Undertakes and then nips in front again on chevrons, the guy is an idiot.
Posted : 15/09/2014 10:54 pm
 aP
Pfffff..... He gets out of the way, he doesn't cover himself in glory. As a public servant he should be seen to be driving correctly, but 80/20 rule?
Come and ride with me on my commute, if that was the worst thing that happened I wouldn't even bother to mention it to anyone.
Posted : 15/09/2014 10:59 pm
I've seen a lot worse. Shit junction for cycling, though.
Posted : 16/09/2014 6:40 am
First let's stop with the "public servant" crap, BTP are employed by the rail companies and as such are not working for the crown. Secondly if this was a private car this wouldn't have been posted, and thirdly, a good measure of whether somebodies driving or cycling was poor is how much disruption it causes to other road users. The cyclist isn't affected at all by this action. Get over yourselves.
Posted : 16/09/2014 7:28 am
Here we go again, another roadie trying his best to start a car bashing thread on a mountain bike forum.
Nobody got hurt or even slightly put out, no laws were broken, leave it alone or save it for the roadie forums so we don't have to get ****ed off with all the up their own arse roadie crap.
Posted : 16/09/2014 7:57 am
Bad journey in this morning travo? 😯
Posted : 16/09/2014 8:00 am
The thread title made it obvious that this is about a road incident. If you're not interested, don't read it.
The cyclist was exactly where I would be in that situation.
The car shouldn't be undertaking, policeman or not, he shouldn't be impatient and undertaking. A cyclist is supposed to be OVERtaken as if its a small vehicle and you wouldn't undertake a small car that way so its not right to undertake a bike that way. Numpty. Personally I would send the video to his boss.
Posted : 16/09/2014 8:30 am
The bike looked to be in a poor position initially and moving over to the right when the lights changed. Looks as though the cop thought he could nip up the inside as the cyclist was moving to the right only to be surprised when the cyclist moved to the left so he had to boot it and pull in.
Poor positioning by the cyclist, should have taken primary in the middle of the lane. Poor planning by the BTP guy, should have just waited.
Posted : 16/09/2014 8:36 am
So it only counts if you get hurt or killed? Are you sure about the no laws being broken?
Posted : 16/09/2014 8:56 am
Which laws do you think were broken?
Posted : 16/09/2014 9:22 am
Bike could have been a bit to the left, it's not that clear what he is doing.
Car drove like a dick, and should have waited, but did at least give space, and I've seen much worse.
Looks like a crap junction layout for cycling, I'd avoid it if at all possible.
Posted : 16/09/2014 9:25 am
Undertaking and then cutting on chevrons.
Posted : 16/09/2014 9:27 am
 m360
Anyone know the BTP response to this "incident".
It is inconsiderate and impatient driving, the type faced everyday. An advanced trained driver should know much better than that though.
Posted : 16/09/2014 9:28 am
The only shocking thing about this is the BTP are actually in a rush to get anywhere!
Posted : 16/09/2014 9:37 am
Leeds City Centre, heading out to Burley Road. Bloody awful junction in a car. Lane priority is too vague, would be safer if the two left lanes were for the slip road to the left and the right hand for straight ahead only.
Not the best way of dealing with it from either party but probably both handling a badly designed junction the best they can.
Posted : 16/09/2014 9:38 am
Undertaking isn't illegal, it's in the highway code not to do it unless you meet certain criteria. A policeman cannot charge you with undertaking, it would normally be driving without due care.
As the lines to the chevrons are broken and not solid they can be crossed if necessary.
Posted : 16/09/2014 9:39 am
Huh? As opposed to the BTP letting the cyclist negotiate the junction and then moving around them?
Posted : 16/09/2014 9:40 am
Most police are not advanced trained drivers .
Posted : 16/09/2014 9:43 am
[So it only counts if you get hurt or killed?]
Or slightly put out, as stated in the post.
I Suggest you read what your commenting on before getting back on that high horse Drac
Posted : 16/09/2014 9:45 am
There's a junction a bit like that on the A1000 not far from me, I imagine others on here will know it. Left lane is turn left, right lane is straight on.
If you stay in the correct lane and avoid the situation where you get stranded on the left and effectively have to cut across a lane of traffic to go straight on, you are riding for a while in the middle of the road. I don't think I have ever managed to stick to the correct lane on that stretch without getting abuse for doing so from drivers. Being a cyclist can be trying at times. 🙁
 D0NK
that's a plus 1 from me
"certain criteria" and "necessary" in this incidence being driver CBA waiting behind cyclist for a handful of seconds (something the camera owner seems to manage ok). The sort of behaviour I'd expect from the more impatient end of the general public, no it wasn't that close but from someone who in a position of authority and should be setting a good example it's pretty poor.
Posted : 16/09/2014 10:02 am
It is when it's not safe to do so, he undertook and had to nip back in on chevrons. All he had to do was wait and he could of overtook him when the road went to 2 lanes.
I did thanks.
Posted : 16/09/2014 10:13 am
...opposed to designing road junctions better to avoid this kind of thing.
Posted : 16/09/2014 10:44 am
 D0NK
plenty of crap junctions around and I fully agree that they should be redesigned, however the BTP driver fell a long way short of "handling a badly designed junction the best they can". lemonysam has already suggested a much better option.
Posted : 16/09/2014 10:49 am
