Broken XTR SPD - Tr...
[Closed] Broken XTR SPD - Transplant from another pedal?
6 Users
Evening all.
I've been riding with SPDs ever since they came on the scene and this weekend was the first time this has happened:
A rock flicked up, hit the pedal and snapped the spring section which holds the cleat in place.
A quick check of the shimano website shows that piece as being part of the pedal body and not available as a spare. Pretty much every other part is available.
I've got a reasonably new set of XT spds which I could remove the broken part from and put on the XTR pedal.
Anyone tried this? Will I lose my finger(s) / eye(s) / sense of humour - there is a spring involved.
Ta in advance.
Posted : 24/08/2020 7:35 pm
I’d just use the XT pedals. There’s no functional difference, and about 17g more heft
Posted : 24/08/2020 8:34 pm
Yes, You can replace that bit and IMO XTR is too good to be dumping over something so trivial, so it could be worth putting a wtd add for an old SPD or for that bit only and the retention strength screw. Actually I might have a a pair of broken 540's I could post you a plate off if you like, drop me a message if so. If not I may be interested in them for the right price 🙂
And also yes, IIRC the hardest bit is getting the spring, that plate, and the retainer screw back together - It's not impossible and I used a strong screwdriver between the spring and that plate to lever the plate into position and get the retention screw back in.
Posted : 24/08/2020 9:41 pm
Maybe worth seeing if you can claim from Shimano? XTR have a three year warranty and those aren't more than a couple of years old. My SPDs have taken a number of stone hits without that happening.
Posted : 24/08/2020 9:47 pm
Op,is that xtr 975 Or later?
I maybe able to help,I've a singular xtr975 in the spares box (that's been what seems forever)but not sure what side it is/if that matters,can check once home tomo.
Posted : 25/08/2020 8:48 am
@lucky13 - Good shout. I'll pursue a warranty claim and see what happens
@duckers - Thanks for the offer. As well as the XT spds I've numerous pairs in my "I'll keep this just in case box" which I can use for that part if the warranty claim comes to nowt.
Posted : 25/08/2020 8:50 am
I maybe able to help,I’ve a singular xtr975 in the spares box (that’s been what seems forever)but not sure what side it is/if that matters,can check once home tomo.
Cheers trap6. Its an M9100 so later than the 975. I'll wait and see what the the warranty claim produces / what lurks in my spares box. If neither come up with the goods I might take you up on that offer.
Posted : 25/08/2020 9:12 am
No worries,let me know if yr in a jam.
Posted : 25/08/2020 10:49 am
I've reassembled ancient spd clip parts but not modern ones without too much difficulty, hopefully similar.
Posted : 25/08/2020 1:42 pm
