Brand-X Ascend II a...
[Closed] Brand-X Ascend II air pressure adjustment
2 Users
I’ve seen reference to adjusting this but can find no illustrations or instructions on how to do so.
Namely the external mounted versions (27.2 in my case), is there a valve under the hex bolt located under the seat clamp? Or is this bolt to be avoided at all costs?
Posted : 12/07/2019 11:23 am
There is no valve on the external posts, it’s a sealed cartridge inside.
Any with pressure adjustment have the valve where the bolt you are seeing is and it’s covered by a rubber cap.
Posted : 12/07/2019 11:31 am
What would happen if I undid that bolt, is it holding anything together?
Posted : 12/07/2019 10:19 pm
The bolt is holding the top of the cartridge. Nothing will happen if you undo it.
Posted : 13/07/2019 10:07 am
