Need a cheapish dropper post for my hardtail, 30.9, preferably 150mm drop but has to be externally routed, can't seem to find a Brand-X one so I'm assuming they only do the 150mm with internal cable routing. As a stealth 'wanted ad', would any STW peeps have anything similar for sale? Cheers in advance!
I would need to check but I think I still have a Specialized Command post 30.9 x 125mm drop thats external routed if that would be any good
Thanks for the response Tracey, not sure if the 125mm drop would be enough, but I'll go and measure again and let you know.
Likewise op - I had to make do with a 125mm external one but tbh could really do with a 150
I’ve got a 150mm Ks Supernatural external dropper on one bike and the cable loop when dropped drives me nuts. If it’s a hardtail can you not run a cable through a bottle boss? I ran a stealth dropper like that on my old Kona Steely. A gear cable outer just about fits. Obviously try it before ordering.
