I've just fitted a new set of XT M785 brakes and on the front if I pull on the brake and rock the front wheel I can feel some play.
It's definitely not the headset, it feels like the pads are moving a fraction and this equates to a couple of mm movement at the tyre (it's a 29" wheel)
I have ensured that the mounting bolts are fully tightened.
Is this something I should worry about, I can't feel any movement on the back wheel.
Rotor bolts tight?
I'm using aftermarket pads in my XT's and the back one does move a bit
Check everything is tight, but it possibly is just the pads moving
It's just the pads moving it the calipers.
I only say this because I made ths mistake earlier today but is the axle tightened all the way up?
Cheers, after posting I found this,
[url= http://forums.mtbr.com/brake-time/xt-m785-pad-play-knocking-814826.html ]XT M785[/url]
Seems like a common issue.
For some reason Shimano make the pads so they have a bit of fore/aft play. Maybe to accommodate heat expansion? Who knows. Anyway it's perfectly normal and you will hear a light clicking on initial application of brakes at first but after a while you won't even notice it.
