At the end of a long ride the other day my rear brake started whistling. I figured changing pads would sort it but it's still doing it.
Any tips?
It's definitely the brake as even a bit of braking pressure stops it
Posted : 06/06/2016 11:33 am
Have you checked the alignment of the caliper? Loosen it slightly, hold the lever, retighten the bolts to centre it on the disc
Posted : 06/06/2016 11:37 am
Whistling brakes sounds ace, have you managed a tune?. I've got a mono water-ski which when the water is dead flat, sounds like a pan pipe.
Posted : 06/06/2016 1:30 pm
We could form a band
Posted : 06/06/2016 1:37 pm
