Brake swap - cable ...
[Closed] Brake swap - cable disc brakes for hydraulic
15 Users
Just got a new bike that came with BB7 cable disc brakes.
I'm thinking of taking them off straight away, selling while they are clean and replacing with Deore or SLX.
Does this seem reasonable or should I just try the cable disc brakes as they are?
Posted : 08/06/2015 10:31 pm
 sync
What bike?
IMO, if its coming with cable bb7s as stock anything over deore would be overkill.
If it's a lower end bike be mindful of the value of upgrades vs buying a better bike to start with. There really are very noticeable diminishing returns in this price bracket.
Posted : 08/06/2015 11:59 pm
Kona Unit 29er singlespeed
Posted : 09/06/2015 6:18 am
Just upgrade the cable outers.
Posted : 09/06/2015 6:28 am
Yep
Do the change to Deore ASAP.
Flog the BB7's on FleaBay and use the money to buy some bling
Posted : 09/06/2015 7:22 am
sync - Member
What bike?
Nonsense. Any bike can benefit from decent brakes.
I'd do exactly as the OP is suggesting - maybe those £99 XTs off Merlin with a £10 discount.
Posted : 09/06/2015 7:25 am
Sigh... BB7's are great brakes
As epicyclo says just upgrade the outers
Posted : 09/06/2015 7:42 am
FWIW, I 'upgraded' to XT hydros after years on BB7s. I can't say I'm blown away by any massive improvement and I'm considering swapping back.
Posted : 09/06/2015 7:56 am
OK, still on topic:
What outers to upgrade cable disc brakes?
APF
Posted : 09/06/2015 8:11 am
charlie the bikemonger does compressionless outers for a sensible price
Posted : 09/06/2015 8:15 am
I'd be tempted by these if I had a cheap-ish bike and wanted hydraulics...
http://www.chainreactioncycles.com/shimano-altus-m355-disc-brake/rp-prod119956
Posted : 09/06/2015 9:22 am
dawson: I'll buy the BB7s off you if you're selling. I'm after some simple, low-maintenance brakes for a touring bike.
Posted : 09/06/2015 9:25 am
alexpalacefan - Member
OK, still on topic:
If you don't mind a bit of fettling you can make your own compressionless outers with a bit of alloy tubing from B&Q.
Once that is done there is virtually no wasted lever movement and the full pull goes into working the brake. This is handy if you ride in muddy conditions because you can set up with more pad clearance. (Which is why I did it in the first place). Or you can set it up as normal, of course. The feel is very similar to a decent hydro.
You can see it here - the outer that does not need to flex is all alloy tubing:
[img][url= https://c1.staticflickr.com/3/2761/5815154075_1c0ea85457_o.jp g" target="_blank">https://c1.staticflickr.com/3/2761/5815154075_1c0ea85457_o.jp g"/> [/img][/url]
Posted : 09/06/2015 10:24 am
BB7s are very good IME, but if you fancy the hydros go for it.
Posted : 09/06/2015 10:29 am
Willf - I bought a clarks CMD15 from CRC, they are a BB7 copy and are great for a tenner, you get rotors and fittings but no levers or cables - Vbrake or standard road levers work with them. For that price you can't go wrong
Epicyclo - genius idea cheers
Posted : 09/06/2015 10:38 am
Can't see why the need to change - I have BB7s and find them pretty good. Good modulation, good stopping power etc,. (this is for XC type riding)
I do use Jagwire Ripcords which I got from Planet X for around £15 but not convinced the difference between 'normal' cables is that noticeable but they do look better!
Posted : 09/06/2015 10:44 am
Thanks for all the responses.
Given the number of positive comments for the BB7's, I think I'm going to try them for 6 months to see how they are, and take it from there.
Posted : 10/06/2015 12:32 pm
Bear in mind that does somewhat reduce the potential resale value of your BB7s though. Nothing like 'new, take off' to get the bids rolling in...
Posted : 10/06/2015 12:38 pm
alexpalacefan and Dawson: Jagwire ripcord outers are good, if you're not sure about the ally tubing.
Worth taking some time to make sure the cut ends are square and smooth when you fit them.
Posted : 10/06/2015 12:54 pm
nedrapier - Member
Dremel is your friend for that job. Tidies up the end nice and square.
Posted : 10/06/2015 1:51 pm
